Upd files
Upd files
From version 2017 on it is necessary to keep drawings and upd files together so as to avoid the "unknown" status of drawings. Drawings from previous versions of Advance Steel need to be updated to attain the "up to date" status. This is a complication because the labels and dimensions will move during the update and the drawing must then be edited. Some users send drawings to coworkers to have them edited or checked. As it is, they must also send upd files and the current behavior complicates the situation for them. They would like to return to the previous behavior as it was in the previous versions without the need to keep track of the upd files.
1 Kommentar
Nicht anwendbar
I agree with you. The problem is also the transition from the older AS version to the newer version. Detail drawings created in previous versions behave like unknown and you musst it update (problem with moving of the dimension lines). The drawing manager should be check the correctness of drawings when we loggin in. The UPD file should be in this case unimportant. Unfortunately we have a lott of drawing in older versions and we need easy checking their correctness without changes.
Idee einsenden
