When running an Audit in Advance Steel, a lot of the times there will be a list of unresolved errors. Typically it will state "Double features found but cannot be deleted" . According to the Autodesk Knowledge Network, one must then manually search and fix the problems by using the "Mark Object" tool. This is a very tedious process.
There should be a way to resolve these kind of errors much faster. Perhaps something similar to Revit's functionality where you can list all errors and then delete them. Would also be nice if you could select multiple errors that are similar and delete them.
