If you use Autodesk Vault as Document Management System, only unique names are allowed in VAULT.
With the change to SQL we have 2 new files after drawing creation which have always the same Name in each AS-Project.
So it is not possible to check in AS-Project into VAULT which includes the files.
Solution
This files should named with Präfix from Modellname.
