UCS on Object with isolated objects
It should be nice if when using isolated objects while modelling the systems allows us to place the UCS on an object!
For large models it's a little time consuming to unisolate all objets just to have the opportunity to select the UCS on object direction, otherwise it won't work, as it doesn't show the UCS view directions.
I expect this is an easy one...
1 Kommentar
ruskie77
Would like to Bump this up to see if there's an answer. I agree with OP
Idee einsenden
