U Bolt
U Bolt
It would be great if we can find also U-Bolts in Bolts library. Many connections in the US uses this type of bolt. There is only one connection with this u bolts, but it is very restrictive. Usually, I need to connect a vertical pipe by a horizontal tube, or L profile.
I attach a screencast with one of this type of connection.
Thanks!
4 Kommentare
bill_justice
I would find this extremely helpful as well. If its implemented, please make the center to center, the diameter and the length variable. This will accommodate piping with insulation.
MichaelAubrey
We have a lot of customers that like to do their own custom handrails, and thus like to use U-Bolts to connect kick plates to handrails. This would be a great thing to have U-Bolts as an option.
Nicht anwendbar
This would be a great idea for having the U-bolts. There are many telecommunication projects using only U-bolts.
Nicht anwendbar
These U-Bolt screws have been used on the transmission towers since 60's. Today it's a standard for the mobile / telecommunications towers. Such a standard will be welcomed by many customers.
Idee einsenden
