Hi!
I am transmisstion tower and substation structure detailer since last 20 years, using AutoCAD 2D only. I have been created small programs in AutoLISP, VBA and VB.Net to expedite to preparing drawings.
Now i am moving into AS for creation this structure in 3D. I have seen in AS for preparing tower profile and connections have to be made manually there is no automatically created some connections, also have to created grid manually in 3D. It is just a line we can not say a grid.
I have also seen Bocad software also and don't want to learn. In this software there is a module for specially created for Transmission tower and substation structures. I have attached image for some profile for connection of bolting with bracing with and without gusset plate, base plate connections , grids for towers etc...
In AS, If my leg is L-Section or C-Channel then is should shown us L or C sections on dialogbox while preparing base plate connection with leg. Now it confuse us if our leg is L-Seciton and AS dialog box showing us H-Column.
It also create leg with two bracings with and without gusset plate as attached image.
Avinash Patil
