Designing the compound beam member requires to "save as" the compound beam type and give the Name to the compound beam to allow reasonable beam marking in basic design drawings. But this compound beam neither its name do not go within the model while working on the same model on several working stations. You need to export/import profile database each time. This procedure is very time consuming - and not practical. I suggest to move this charakteristics from the built-in databases to the project databases.
