Tolerance for washer
Hi guys,
When you create washer plates in the Base plate [3] automatic connection from the connection vault you have access to add washer plates. You also have the option to modify the tolerance of the hole of the washer.
However, this option disappears when using the Corner base plate [15].
Please see printscreens attached.
Thanks!
Idee einsenden
