T Section Handrail Connections
Hi guys!
Is there any way to have Advance Steel use WT sections for handrail connections to the side of beams?  I know of the angles and "T" Plates, but it seems to be more common these days for Engineers to be asking for actual WT sections.
As far as I know, the only way to get this done is to remove the connection box and add them manually.
Please see print screen where said connection would be nice to have.
Thanks!
1 Kommentar
pinnacledrafting
Definitely some improvements can be made here. I was told once of a way to get additional sections for the posts and rails by modifying the database, but I don't know if it can be done for the mounting sections like you are suggesting.
Idee einsenden
