Steel to Wood Connections
It would be nice if there was an option in the connection vault for steel column caps similar to Simpson CCO or ECCO for wood to steel connections. Currently it takes many steps to model these column caps and is time consuming especially when trying to detail these caps as multiple parts. To make it more simple it would be nice to be able to choose the column cap connection tool, then choose a beam with beam end or reference point for the cap. Also have it be able to rotate on the column as desired, and to be able to fully adjust all the dimensions of this connection. Also with options to create a bent plate or welded plates. I use these kind of connections frequently so this would help greatly! Thank you.
6 Kommentare
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
ecapati
Is this already been added for v.2018 student version?
a1iron
This is a great idea. I use the "saddle" plate connections a lot. It would be nice to also have the option of placing this on the side of a column, on the side and end of a beam as well. I have seen all these variations in commerical buildings. I have a library that I have built over the years that I use, but it would be nice to have them as macros.
pinnacledrafting
I've been wishing for this one for years. I even suggested it in the old graitec forums. I hope it gets implemented.
ecapati
Did autodesk include this connection on v.2019?
gene.nasierowski
Are these Simpson connectors available for wood to wood timber beams?
I need them too. AS 2023
Idee einsenden
