In the stair macro, it would be useful to have greater control over the bolts.
For example, I have chosen tread type 7 with a bolted / bolted option, I need CSK bolts in the treads but want XOX bolts in the stringer, once you change to CSK all bolts change, without deleting the joint box to manually change the bolts there is no option for a mix of bolts.
I would also be handy to control the number of bolts, sometimes we may need to model stairs with extra-long goings and need 3 bolts to stop the treads rattling. Currently there are no bolt control options for the number of bolts.
