Square holes
Square holes
Within the holes there is no opition for a square type of hole, lots of other types.
We get this request all the time, for users placing in HD bolts and making plates to form the bolt box base, they want to punch a square hole, so we have to tell them to use a contour to create it and array or polar array.
Be a lot easier to create a hole pattern an then set the parameters for the setting out, then just change the type from round to square.
3 Kommentare
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
markhubrich
Yes please add square holes!! I'm sure it's not nearly as complicated as slots or countersink. :leicht_lächelndes_Gesicht:
deleondaviding
Observer
SI SERIA UNA BUENA OPCION PODER COLOCAR BARRENOS CUADRADOS CON OPCION DE ALINEARSE RESPECTO AL EJE DE LA PIEZA QUE SE CONECTA.
Idee einsenden
