Special symbols and special characters in dimensions labels
Hi Dev's,  We need special symbols and special characters drop-down menu or sim to be included in dim labels, Thank you.
7 Kommentare
bigcarl5000kg
Which one do you miss the most?
acbsdesign
Diameter Symbol
bigcarl5000kg
Why can't AS recognize automatically a hole & Co. for dimensions? I mean, for example your objects in the section ... this is a basic task for a 3D CAD. It also handles Autocad Mechanical with its objects, and it's just 2D.
Maybe I misunderstood the idea, but this is existing or not?
acbsdesign
@Sebastian_Eiche
You are the man! Thank you very much.
bigcarl5000kg
Manual notice is a nice thing, but impractical in the available form... look at another solution = Autocad dimension modification. But it's still not automatic recognition of the object (eg. hole in each form) in the section for some corresponding dimension.
the question is: how often do you use a symbol in dimensions? It could  be done with a label without problems. and the hole is not dimensioned because it's hole, the contour of the plate is used.
I'm with, it would be nice, but for my point of view, we have much possibilities do get a good result.
For me it would be good do have a setting in the dimrules of the drawing style which dimstil should be used. And if then the suffix and prefix will work...all problems are gone
Idee einsenden
