hi,
in several cases we have small sloped ends on a beam when we make a connection.
It wood we nice iff we can avoid this small sloped ends, or overrule the sloped feature with a switch in the macro.
for example this one:
it is only 1mm and it gives a lot of work and also costs to saw this 1 mm sloped.
It is easy to saw it straight and costs less and less failures on the workfloor.
And the 1 mm we can weld it still, openings up to aprox 4mm are good to weld.
