Often we need to finish fabrication of miscellaneous items in the field. We leave them long and field cut. Advance steel needs to have a site or shop option for cuts. With a site cut the assembly and part drawing should show the piece to the axis node end. For General Arrangement Drawings it should show the piece as in the 3d model. If the piece is lengthened from a connection and longer then than the end of the node there should be a setting for field cut length extension that the shop drawing goes by.
