Show Shape size label in Model Space
Create an option to turn On (show the label) of main parts shape size in model space. Even better if we can turn on by member role, or by selected members only. This will allow the user to verify that the input member has the correct shape size. In big framing plans it is difficult to track every member.
The rollover tooltip sometimes doesn't work properly.
2 Kommentare
FCort
To be more explicit., see the pictures. This will help to do a quick verification when overlap an underlay contract drawings, and will be very fast procedure, instead of using the tooltip or opening the AS properties individually at each member.SHAPE LABEL1.JPGSHAPE LABEL2.JPG
Nicht anwendbar
Yes, yes, yes.  And having the mark number would be helpful too.
Idee einsenden
