Shear Plate Macro-default hole diameters to be variable 1/16" larger than bolt d
Per attached screen shot, variable hole tolerance in Shear Plate macro is set to ZERO by default.
Holes are never same diameter as the bolts.
Please change default holes to be  variable-1/16" larger than the bolts diameter.
Ilko Dimitrov
2 Kommentare
haedicu
Status geändert in: Implemented
Hi Ilko,
I think, this is a bit confusing in the connection dialog. As it is implemented now, the hole tolerance is specified by the default from management tool. In a typical US installation it is already 1/16" as you can see in the pictures below. The value can be used to specify a hole tolerance different from the default.
acbsdesign
Hi Udo,
No, even if default tolerance is set to  1/16", shear plate macro's default is zero.
Thank you for looking at this.
Ilko Dimitrov
Idee einsenden
