Shear plate dimensioning in column views
Currently, using the default Advance Steel dwg styles for column (including latest release), shear plates to center of column dimension (ref. attached
screen pic) jumps to the other side of the column by default-typ for all shear plates.
This does not make any sense. Shop is laying-out shear plates from one side and it is measuring the center of column to the shear plate distance from
same side, no reason for this dimension to go over the column and snap to the other side.
It is snapping to the side that touches the column, it shall snap to the free edge side and teh free edge corner point.
It is very repetative, this shall be fixed.
Ilko Dimitrov
4 Kommentare
acbsdesign
 This issue gets bigger when we have two shear plates on each side of a column, located 180 degrees from each other, the dimension for the top
shear plate snaps on the side of the bottom shear plate and opposite-the dimension for the bottom shear plate snaps on the top side, creating
confusion for the shop, especially if the two shear plates do not sit one one plane-this may create a fit-up issue.
haedicu
Status geändert in: Accepted
Thanks a lot for reporting this issue. We will take it in consideration for one of the next releases.
best regards
Udo
haedicu
Status geändert in: Implemented
Advance Steel 2017
acbsdesign
Hi Udo,
Column sections at shear plates are better dimensioned now, nice and clean.
Thank you for working on this, it helps also preventing errors in the shop.
Ilko Dimitrov
Idee einsenden
