Shaped Cameras
Shaped Cameras
The ability to create irregular shaped cameras and have grip points on each corner.
1 Kommentar
Shawton2000
Great comment,
At the moment when I produce stair core layouts I use 3 individual cameras for each flight necessary to detail. An irregular shaped camera would make life way easier.
The grip points for cameras should work in the same way as modifying an auto cad rectangle, where by when a corner is picked to be stretched the opposite corner point stays static instead of all corners displacing in proportion to the one selected.
Idee einsenden
