Separate classes for "Straight beam" and "Poly beam" and the possibility to filter these beams separately
Dear Devs,
under the designation "ASTBEAM", several beam types are created, which does not allow filtering of each type individually. The selection filter for beams (AstM4SelectObjectByName_ ASTBEAM) did not make any differences between "Straight beam" and "Poly beam" - both types of these beams will be marked.
We need separate classes for "Straight beam" and "Poly beam" and the possibility to filter these beams separately.
@Gernot.Jeromin - can you please look at this? Many thanks in advance.
Idee einsenden
