Separate assemblies from standalone parts on BOM
on the structure lists, it would be nice if I could separate the assemblies (more than 2 objects) from the standalone parts (asssemblies with only one object inside).
The best way would be with a "line" or "space" between them.
I could use the selection of objects, but if I would have all in one single list, will be better.
Regards.
2 Kommentare
Emanuel.Nestor
Autodesk Support
Hi @Anonymous
Thank you for posting your feature request.
If I understand correctly, an additional option like "Separate Standalone parts" in the "Report content" would work. When the option is activated, the standalone parts would be grouped separately from the rest of assemblies.
Best regards,
Emy
in theory we could do it now. In the model: filter for standalonepart, give them a lot/phase like "Standalone" if you now use a structured list which is structured by lot/phase, they will be separated.
Another way would be, to define an extra userattribute in the model like Userattribute 1 and then input a field with this content. After this set the view state to "off" (so it will not be seen in the bom list). But if you have a field with the content, you could sort by this content.
Idee einsenden
