At time, the offset for the sections (profiles) is parallel to the system line possible.
Please add:
- independent offset possibilities at both ends of the system line in the Y / Z direction.
- alignment in the case of subsequently mirrored / rotated profiles - the Y and Z values for the offset are often mixed up compared to the original position, the user must also test the behavior / input in order to be able to move in the desired direction.
