Section View Grips
Section View Grips
I would like to have grips at each corner of the green section view outline boxes. The grips could be used to easily size and locate the viewable area of a section just cut from the current drawing.
I am finding that I don't always get what I am hoping to see when cutting a section on a drawing. When I go to make adjustments by changing the X and/or Y values in the view edit window, I am not always able to get the view I would like. If I could simply grab the grips and move them around the position I need them to be this would be a very easy solution for adjusting your section's viewable area.
I would prefer this over leaving the drawing and setting up a new camera or view in the model and the coming back o it in the drawing.
Ray B.
4 Kommentare
pb-sb
Die „Schnitte aus Detail“ sollten auch in Einbaulage (positive Z-Achse oben) auf den Plänen erzeugt werden können. Diese Einstellung muss wählbar sein. Weiterhin sollte die Breite des erzeugten Schnittsymbols im Detail auch der geführten Schnittbreite entsprechen.
The "cuts from detail" should also be able to be generated in the assembly position (positive Z axis above) on the plans. This setting must be selectable. Furthermore, the width of the generated cutting symbol should also correspond in detail to the guided cutting width.
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
acbsdesign
Very useful idea, Ray B.,
I would vote another 99 times if i could.
The only cons may be if this causes drawing to be overcrowded for editing,
probably it would be helpful if we can turn grips on and off from the detail view dialog.
Ilko Dimitrov
DumitruBerteanu
Idee einsenden
