Section Arrows need to be making use of dynamic block opitions.
The section arrows are symbols in the symbols folder, inserted into drawings when cut/section views are created.
opition for section arrow type are limited, it can be changed to another 2d cad design, but it is static.  For example the text is fixed in rotation, some section arrows required the rotation of the text so as to view correctly on the drawing.
can the section symbols be made to use the dynamic block , where opitions to rotated the text and possible the arrow part.  Also there should be token system to link cut views that are placed on other drawings.
the whole symbol tech , needs to overhauled to make the blocks and use more inline with normal autocad 2 d  dynamic blocks.
Idee einsenden
