search filter string search
according to this thread: Search filters
If we want to search for more then one UserAttribute we don't have the possibility to add more then one information. I understand the UserAttribute is a string which could include maybe a semicolon, but therefore a special separator would very nice.
So by using this special separator it should be possible to filter different content of the same property.
Example like in the thread: different beams have different userattribute1 properties...
beam 1: Userattribute1--> elevator 3
beam 2: Userattribute1--> elevator 4
beam 3: Userattribute1--> elevator 5
The best way should be so search for "elevator"*#;#* --> search all userattribute1 with "elevator" and all things which come after this string.
Or to have the possibility to search for more than one content, with a special separator like ;;;-;;;
  • elevator 3;;;-;;;elevator 4;;;-;;;elevator 5
6 Kommentare
Emanuel.Nestor
Autodesk Support
It would be nice also to be able to use wildcards ( *, ?).
that's what I mean with the first point *#;#* this should be like a wildcard
Emanuel.Nestor
Autodesk Support
Ah, yes indeed :leicht_lächelndes_Gesicht:
TvdH1981
If I understand correctly, then it's possible what you want.
If you use the searchfilter then search under userattribute 1 and separate the search bij ;
for example like this.
elevatot 1;elavator 2;elevator3; etc
I use it all the time to select phases etc.
yes in phases this works, but not in userattributes
TvdH1981
Yes I see it too now. Sorry I coudnn't help out
Idee einsenden
