we often have the problem, that we want to add a specific setting for specific welds. For example: all welds which are bigger than 5mm should have an information, that these welds should be controlled.
So I want to select all these welds with a few clicks and use the AdvanceProperties to change something.
In the filter search of Advance Steel I could search for specific weld thickness like 4mm,5mm,6mm, but for this I had to know all thickness which I use in the model.
But this is not useable. In the filter search of Advance Steel it should be possible to use "<" and ">".
This is maybe useable for other properties too, for example: all beams HEA bigger than 240.
regards
Sebastian
