The ability to create a screw set with welded studs together with washers and nuts would be great.
This set uses only one hole for the bolted profile. Obviously it does not use a screw head for the welded side.
By now I solved this by doing this with special parts. This lacks of comfort in comparision with using the bolt tool.
This needs changes to the database format. And a graphical representation too.
