Having different Linetype scale in the objects Properties affects the views generated by using FLATSHOT AutoCAD command.
In the picture it is highlighted the current behavior.
For having in the views same linetype, the Beams and the Bolts must have in Properties the Linetype set to 1, as it is set for the Plates, Gratings, Anchors....
