Round cuts dimensions to be improved
Default SP Beam TopDefault SP Beam TopManual DimensionsManual Dimensions
Guten Tag,
Please improve the round cut dimensions per attached two screen shots above.
Used dwg Style: SP-Beam-top.
End was cut using Element Contour-Rule, pipe to pipe.
Freundliche Grüße
Ilko Dimitrov
2 Kommentare
acbsdesign
I would like to add also the beam cope cuts-on some occasions using the shear plate macro beam copes show not with a clean radius,
but as multiple cuts, having multiple dimensions instead of only one vertical and one horizontal and one radius.
Beam cope dimensionsBeam cope dimensions
Julio_Soto
Yeah, the way AS dimensions or displays anything round is pretty rediculous. It not like we haven't know how to calculate the circumference of a circle for FOUR THOUSAND years.
Idee einsenden
