Rotate beam or change system line position with key combination while placing a beam
When you model a beam you have to click on enter/space/rightclick to get into the property box. There you can rotate the  beam 90 degrees or 180 degrees. Would it not be nice if you model a beam and then you can click  for instance on "CTRL" and then the beam rotate to your wish.
Also maybe a key for changing the system line position before you place the beam.
Idee einsenden
