Dear AS/Revit/SMLX Developers,
the current model transfer from Revit to AS is not allowing the transfer of any hard coded or custom marking parameters properly (e.g. Type Mark, Mark, custom Project Parameters). The only parameter coming across is the "Comment" that is appearing in AS as the "Pre Defined Remark" but this is not updating when models are synchronised.
Therefore, labelling members in AS drawings with the matching engineering marks from Revit is not possible without manual input of the engineering mark into an AS member User Attribute.
This is a major obstacle for consulting engineers to use Revit as the main BIM platform and AS for the production of engineering details.
To start with, It would be sufficient if we could map a specific Revit Parameter with a property in AS.
Ideally, we had a parameter available in AS (incl. tokens) called "Engineering Mark". A mapping setting in the SMLX Import/Export dialogue to map any Revit hard coded or Project Parameter to this AS "Engineering Mark" parameter.
It would help very much if we could get the parameters across in some way.
Thanks very much!
