Resizing Windows&Dialogs
The idea is to have all the dialogs capable to be resized, similar with the "Drawing Style Manager" dialog.
4 Kommentare
jess_neal
This is a BUG  and not a new idea. Please treat it as such.
acbsdesign
This is something to be fixed without voting, why you would put this here.
The way you work is disappointing.
Nicht anwendbar
 Since Autodesk is incapable of doing their job, ill do it for them - this item is under development after way to much work on the users part.
https://forums.autodesk.com/t5/advance-steel-forum/as-a-client-and-shareholder-im-not-impressed-when...
Status geändert in: Implemented
all dialogs should work now in a way that you don't need to re-size them anymore, even if you are using a high dpi resolution. This has been done in Advance Steel 2020.
Gernot
Idee einsenden
