Referencing current UCS when copying and pasting with basepoint
The copy clip command seems to only work properly if my UCS is at World. If I move my UCS to an object and use the copy clip command it pastes the object far from the point from where I have selected. Using the copy clip command with non Advance steel objects works normally. When I paste the advance steel object it looks like it is referencing the world UCS not the current UCS. While I can paste then move and rotate the object to the correct position it is a lot easier to just manipulate the UCS and paste it where I want it. This is happening when I copy clip between DWGs and also in the same DWG. I use copy with basepoint daily and it would be great if this could be fixed somehow.
2 Kommentare
haedicu
Status geändert in: Under Review
haedicu
Status geändert in: Archived
Due to a low support of your peers, your great idea is not considered for implementation at this time. Thank you for your contribution, every idea has merit. We always encourage you to rework and resubmit these ideas based on feedback received.
Idee einsenden
