Radius not wanted - Drawing Style Manager
I have recently made changes to the ‘Drawing Style Manager’ views to ‘Visible (Exact) Hidden’ as needed so as to show all radius of members.
The issue I am now having is I can also visually see all radius of member in elevation view as well.
Thus when you are looking from the end view of your UB, PFC etc it shows the radius, this is what I wish to keep. But when looking from the side (down the length of a member) you now see three line and not two, meaning top of flange, BTM of flange and the third line is now the radius.
Any help in turning this third line off (the radius line) from the side view would be greatly appreciated.
1 Kommentar
Julio_Soto
It would be great if AS could treat these tanget lines seperate from the rest of the objects. For your simple example just use an object presentation for side views that show "standard" presentation instead of "exact". Just remember if you have a miter cut, the miter profile will not show the radii
Idee einsenden
