Quicker Quickviews
Quicker Quickviews
Quickviews on parts, assemblies joints right now need 7 mouse clicks, because you either confirm or change settings for clippings.
Needed are 3 clicks for a really quick view: select command, select part, select view direction= ecs vector.
Optional settings could be activated by using control or shift.
Also besides centered object view  there should be additional functions like object view at point, centered view on face, view on face at point etc.
And: What is the difference between quickviews on parts, joints, assemblies? Although the buttons are calling different commands- _AstM10QuickObjectView  & (Object or Assembly or Joint), I have the feeling they are all doing the same.
BR,
Christian Blei
1 Comment
haedicu
Thank you for this idea.
We will take it in consideration for our future roadmap.
best regards
Udo
