Profile Manager
Profile Manager
Add an ability to work profile base much more friendly.
Tool in Management Tools that will open a window with profile base and take to user ability to:
1. Add new catalog by every section shape.
How I see that: User can create new catalog, choose section type and load a csv file table. CSV file with parameters like lookup tables in Revit that consist all needed parameters (dimensions, names and other). Table template for every section shape type should be installed with Advance Steel or downloadable from online help. That base should be upgradeable. This section base need to be synchronized with Revit sections shapes. It will help with collaboration between Advance Steel and Revit.
2. Hide old or not needed shapes.
How I see that: In every catalog should be a checkbox that will show/hide this catalog in workflow. This checkbox should be able to every profile. That will help use only profiles that are manufacturing in each region.
1 Kommentar
part 1:
new profiles could be created very easy by using existing profiles and otherwise: by creating user profiles based on lines. If you want to have it like Revit, the whole base of Advance Steel had to be changed. Advance Steel could handle profiles based on databases, these need to have specific columns. The base of Revit and Advance Steel are different, so from my point of view, there will never be a similar dataset for it.
part 2:
this could be done by using the preferenced sizes. Set them and you will just see, the profiles you want or under "all" all profiles
Idee einsenden
