Print drawings of selected elements in model only
Hi Devs, Is this possible to be implemented-printing drawings only of selected elements in model. Thank you.
2 Kommentare
Status geändert in: Gathering Support
can you explain a bit more what you are looking for exactly?
You want to select objects in the 3D model, and if there are existing 2D drawings (assembly, single part, ...) they should be batched printed / plotted.
Is that correct?
Gernot
acbsdesign
Yes, this is correct, thank you.
Idee einsenden
