Show only
Search instead for
Any and all suggestions that make drawing editing/updating easier and quicker should be given top priority IMO. As well as document management improvements...
If I were the chief in the kitchen this is what I would do first:
1. Once dimensions have been adjusted - block EVERY dimension update during dwg update, and if a dimension needs to be changed-either make it Red or Cloud it, we will move points or delete points as necessary manually.
This has to be an option, and it has to be in detail view dialog window. On in MT. User will make decision whatever dimensions to be updated manually or automatically depending on the project.
2. Once labels are moved or deleted-do not update / move them, make them red or cloud them, we will update or move manually if it is necessary, this has to be an option in detail view and let user decide which way to go.
3. Prevent compass mark to move or appear during detail update if it is moved or deleted-an option to be included similar to 1 and 2 lines
4. Prevent detail cut view title form moving during detail update
5. Make depth of view available again in detail dwgs creation, new 2017.1 dialog is terrible
I ask all users who support these few lines to help draw attention.
GREAT SUGGESTIONS NOW I BELIEVE ALL THE ADVANCE STEEL USER ARE FACING SAME PROBLEMS PLEASE FIX THESE ISSUE AS SOON AS POSSIBLE POINT 1 SHOULD BE ON THE TOP PRIORITY
