AS the post Emy NESTOR 10-20-2016 archived (with more angles)
When generate a folded plate, the default radius of the fold relation is 2 times the plate thickness.
The request would be to have the possibility to change or set a different multiplier for the default radius - 1 times the plate thickness or 3, as example
And Angle 45° 90°
Thank you very much
Corentin
