polybeam representation in drawings
I would like see an object presentation setting that will show just the outline of plybeams. I have to use polybeams for a lot of my railings and bent pipe in order for it to be marked as a single piece. The problem is that they show up as a mess of lines as if it was a folded plate (see attached screenshot). There is no good way to display them currently. Another fix I think would be fairly easy... Let s get some votes!
2 Kommentare
Nicht anwendbar
You need to customize your drawing style. This video was done fast so its a little weak but you get the idea. Once you setup your drawing style for all your assemblies (Angles, Channels, Beams, Rails, Stringers, Columns, Plates) then you put them into your drawing process and it will detail everything out for you. Hope that helps!
Nicht anwendbar
I have done lots of DS customization, but like I said, in the object presentation there is no good way to represent polybeams. I have to use polybeams for most of my bent pipe members, and there is no representation to see just the outline. IF it is visible it is a jumble of multiple lines that does not plot well at all.
Idee einsenden
