Please make revision control / clouds more user friendly
Currently, if we have to rev. down let's say 20 dwgs, with already clouded members made by Advance-we know how messy they can be-revving down does not erase previously made clouds.
Please add an option either quick select+delete all clouds in a dwg, or make revving down to delete also the revision clouds.
This will save us time, and less frustration deleting messy clouds.
Also-please make an option to rev down multiple dwgs at once, edit revision of multiple dwgs in one dialog window only, not having to edit each dwg separately.
This is very time consuming.
In other words-please make this more intelligent. It feels undeveloped.
Ilko Dimitrov
2 Kommentare
haedicu
Status geändert in: Under Review
Thanks Ilko,
we will dig into the requests and prepare an answwer for you.
best regards
Udo
Nicht anwendbar
I totally agree.
I found that forcing the update on drawings erase all previously activated clouds by AS. This have saved me a lot of time but messes with cleaned up drawings. I still wish there were a simple solution and we could erase a revision on several drawings at once. I usually use "force update" and rev up my drawings only before sending them to my client. Also I put manually the clouds where I need them because the ones AS does are kind of a mess.
https://forums.autodesk.com/t5/advance-steel-ideas/better-revision-control/idc-p/8990331#M3773
Idee einsenden
