PLATE SIMILAR TO BEAM PROPERTIES
I would like to have the ability to have the macros in connection vault expanded to include PLATES that act as "beam" members.
We deal with 3pc welded members and quite often the "compound or tapered" properties have to be exploded into a welded plate assembly (as we cannot build/import the correct shapes with the WELDED BEAMS, TAPERED builder) . We would still like to connect beams, angle bracing etc to the web or flanges of the assembly.
ie: DOUBLE SIDE END PLATE, DOUBLE SIDE CLIP ANGLE, GUSSET PLATE AT 1 DIAGONAL, SHEAR PLATE etc. support only BEAM objects.
1 Kommentar
haedicu
Status geändert in: Future Consideration
Thank you for this great idea. I agree that this will help on the modeling and save time on your side.
We will take it in consideration for future releases.
best regards
Udo
Idee einsenden
