Plate on Plate perpendicular on center – Building brick.
Building bricks in a custom connection panel are a very powerful tools.
Therefore it would be a significant enhancement to have a ‘Plate on Plate perpendicular on the center.’
Few scenarios for the use of it, there are plenty throughout the projects ↓
2 Kommentare
the custom connection would be usefull, but additional, some of these could be done by using the pipe connection of the connection vault:
e.kajackas
Hi @Sebastian_Eiche
Thank you for your comments.
I’m aware of ‘Single Tube Brace Gusset,’ you talking about here, actually have investigated it properly, with the hope to be able to use it.
It would be a very powerful tool. However, unfortunately, it is half done e.i. no use in our line of work:
  • The gusset plate needs to be in the middle of the column; therefore, when shifting geometry to achieve that, the gusset clashes into the tube.
  • Option to have gavl. holes in cap non existent.
  • Plate shape options not suitable for us - adding features to get the required shape has its limitations. For example, if used as custom connection features have their own mind upon placement.
Idee einsenden
