Parametric Center Lines for dimensions
Many dimensions placed on drawings are to centerlines.
It would be good if we had a command that would place parametric centerlines between two straight edges.
Then we could use these centerlines for parametric dimensioning.
If the edges are moved, the centerlines would move too and the dimensions would remain correct.
2 Kommentare
haedicu
Status geändert in: Future Consideration
Hi FProcp,
it would be great if you could add a bit more information to this idea? The edges you are talking about are from beams? plates? other objects? Are the 2 edges from the same object or can they be from different objects (e.g.: top and bottom flange plate of a 3-plate-beam)?
Perhaps some pictures would be helpful understanding your requirement.
Many thanks and
best regards
Udo
FProcp
Hi Udo,
Sometimes we may need to dimension between the centerlines of columns or
around the center of a structure as in the images below.
We should be able to add parametric centerlines in all the places you
mentioned, i.e. edges of beams, plates, other objects and between 2 edges of
the same object or different objects.
Idee einsenden
