Order in assigning preliminary numbers
Currently we do not have an option to assign preliminary numbers per shape, size, thickness order.
The submitted advance BOM to fabricators if sorted per preliminary mark it will look with shapes and thicknesses messed up everywhere.
If ABOM is sorted per name, then the preliminarty numbers are all over the place, and this is in  contradiction to many fabricators' practice to reference
the preliminary number to trace what was purchased etc.
There should be an otion to assign preliminary numbers in order the material list is created -sorted per name, length, thickness, with preliminary numbers following same sequence.
Currently we are selecting all angles, or all W-shapes and run the numbering assigning preliminary numbers as close as possible per name, length, thickness etc. and it is a time consuming process.
Ilko Dimitrov
2 Kommentare
haedicu
Status geändert in: Future Consideration
Thank you for this great idea. I agree that this will help getting a clean order for parts and numbers.
We will take it in consideration for one of our next releases.
best regards
Udo
suesLPLV6
Thank you @acbsdesign reading this post allowed me to solve a huge issue we were having with numbering.  Thank you....thank you....thank you....
Idee einsenden
