It would be nice to be able to ensure the same camera veiw is not drawn multiple times.
With the "Allow duplicate workshop drawings" default turned off a you can use the "All parts" or "All assemblies" drawing processes to catch any new drawings required after editing and renumbering a model without having to know exactly where the new parts are.
With cameras, you can set new cameras up and set the Type property but unless it is the first time you are using the Cameras drawing process you cannot use an "All Cameras Type" process to draw them as you will get the views of previous cameras drawn again. So currently you must manually select the new cameras and use "Cameras Selected" drawing processes. If we had a way to prevent the camera views being drawn more than once we could use the "All Cameras Type" processes to qucikly draw the new cameras only.
For exmaple: Create 5 Node cameras. Use "All Cameras Node" drawing process. Edit model and add joints. Add 3 more Node type cameras. Currently you have to select the new cameras and use the "Selected Cameras" process. If you used "All Cameras Node" again the first 5 will get drawn again as well as the new 3 (Making hte Type property of the camera pretty useless at this point). With the new option you could use the "All Cameras Node" proces safely.
This should probably be a simple Default "Prevent duplicate drawings of cameras" or similar.
Thanks.
