Open SP dwg from MP dwg with a right click
Hi Devs, we should be able to open SP dwg when cleaning up MP dwgs with the Edit shortcut menu. Thank you.
2 Comments
tommyQD7G6
It would also be great if we could create a single part drawing directly from an assembly drawing.  Example - when detailing railings sometimes we like to show a single part detail of the base plate on the railing assembly drawing: if we could just click on the base plate, select create drawing and have that drawing show up on the MP drawing it would save some time.  Currently we usually create that part separately and just add it to the MP drawing.
acbsdesign
Yes, it would be great if we could do that.
