One label with one arrow for multiple objects
We need to insert only one label, with only one arrow for some identical object inside the classic area managed from the label.
Please look the picture attached.
Thanks.
9 Kommentare
Nicht anwendbar
Additionally the inverse would be helpful, the option to put multiple pointers on a leader line to reference many of the same object. It could function like current insert Point/Delete Point option in the Parametric Dimensions Ribbon, just call it Insert Label Point/ Delete Label Point on the Labels Ribbon.
iwafb
Also requested over a year ago, but you explained it much better... Smiley (fröhlich)
https://forums.autodesk.com/t5/advance-steel-ideas/grouping-option-for-labels-in-detail-style/idi-p/...
As it stands, the current option to "group" labels is pretty much useless because of the multiple leaders...
Status geändert in: Implemented
this has been implemented in Advance Steel 2020 and 2021.
By the way: if you like to have a look at what is new in Advance Steel 2021 (besides this issue), please have a look here:
https://forums.autodesk.com/t5/advance-steel-ideas/2018-version-please-prevent-moving-of-dimensions-...
Gernot
Drawtech
Hi Gernot,
This was NOT implemented in AS2020.
Below shows 2 hole patterns (single sided endplate joint) and the labels are combined but there are 2 leader lines.  We only want one leader line in the same way it would be if it were a single hole pattern of 6 holes.
...so unless it was implemented in AS2021 (I have not installed it yet), it remains a very much wanted but NOT implemented feature request.
Dave
Drawtech
Hi @Anonymous,
Any further comment on this?
...it is NOT implemented right?
Dave
Nicht anwendbar
Hi @Drawtech I'm working on AS2021 and I haven't seen any option to fix this issue. @Gernot.Jeromin would you be so kind as to show me how to fix this is AS2021
Thank you
Drawtech
Why is this STILL marked as implemented.
...it isn't!
Is this idea station completely ignored by Autodesk these days?
Status geändert in: Accepted
cj4HG5A
NNN years later, it still hasn't been solved. It is difficult to? Or just ignore it?
Idee einsenden
