Offset for Bolt Connections
It would be nice, if there would be a way to give bolt-heads an offset.
A positive offset is necessary to "connect" solids or special parts and keep the bolt connection intelligent and get the right bolt length
A negative offset is needed for sinkholes or platforms.
1 Kommentar
DumitruBerteanu
Status geändert in: Gathering Support
Hi Thomas,
Currently in Advance Steel the bolt "detects" those situations - an attached solid, or a sinkholes, and places, the bolt head at the expected level, with a positive or negative offset from the main connected element. This offset can't be set indeed, it is calculated. Would there be situations where this automatic determination of the bolt head position is not enough, and a manual offset is needed?
Idee einsenden
