New model role for galvanising holes for better drawing output
Workshop drawings start to get really messy when you need to add holes for galvanising.
I generally label and dimension galv holes in part details only. ...and then they generally need a lot of editing for neat presentation.
On the assembly details, there is no real need to dimension or label them.
...so to achieve this in drawing styles, we need the galvanising holes to have a different model role.
When creating holes manually in the model, we could then pick the hole type as "galvanising hole" rather than round hole.
Similarly, all joint macros would need to be updated to use this new role for galvanising holes.
1 Kommentar
ETheuring
However, for it would make sense if a model role could give to holes in general first.
A galvanisation hole is at last nothing else than a round hole.
There is the same problem also with building site holes. They should not appear in the NC data at all and have a certain icon in the drawings.
One can give bolts though a model role, but this model role has no effect on the hole.
Idee einsenden
